| Home > Help Needed / General Tech Chat > Thinking of going turbo | |||||||
22 Posts Member #: 12187 Member |
1st Dec, 2021 at 11:04:54pm
Hi guys I am doing a full restoration on my mini and I am the point of doing the engine and gearbox. I have a couple question about turboing it.
264 Posts Member #: 11029 Senior Member Crewe |
5th Dec, 2021 at 10:23:52am
Have a good search around all of the answers to your questions will have been answered already.
Outside the box |
257 Posts Member #: 11017 Senior Member Shropshire |
7th Dec, 2021 at 04:23:44am
On 5th Dec, 2021 monsterob said:
Have a good search around all of the answers to your questions will have been answered already. low power - con rods will be fine im using standard ones. I think the std gearbox can take up o around 130 ponies Pistons i am using cast dished omegas - but yo need to research compression ratios as thats where i would start as its the fundamental for the rest of the build. search is in the menu at the RH A+ rods will take north of 200bhp. |
15th Dec, 2021 at 08:03:35pm
Great thank you guys for all the help. There is alot of info on this website and some of it is confusing to be honest. All I'm trying to find out now is what compression ratio/boost do I need to run to gain 120bhp. |
10 Posts Member #: 12185 Member |
16th Dec, 2021 at 08:22:50am
Metro turbo was 9.4:1 if I remember correctly can could be safely pushed to 110. I'd you're wanting a 120hp I wouldn't go too low and be sure to fit an intercooler |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
16th Dec, 2021 at 10:27:58pm
If your aiming for more power in the future (as most people end up doing) try to cover all bases at an early stage to save revisiting and inevitably doing things twice.
16th Dec, 2021 at 11:54:43pm
Max I'll be going for is 130bhp |
