Home > Help Needed / General Tech Chat > Oil Drain from turbo
RED850
Member #: 89
Sydney Australia
Hi chaps,
odd question here is th ebreif I have never used the STD oil drain from the turbo through the fuel pump hole as i never thought it was good enough as it is gravety drain and this drain is virtually horizontal. so my question is can someone with a std metro turbo set up measure how far down from the exh manfold bolt up hole the oil drain out of the turbo sits?, I have changed turbo's and no longer have the std turbo to measure and i am unsure if i can now use the fuel pump hole.
thanks heaps
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
my advice to you my friend would be to use this purpose! hole in the block as the oil drain for the turbo as its more than up for the job intended
you could fabricate a plate & use some fittings for this purpose not a big job at all!
