Home > A-Series EFI / Injection > Vmaxscart EFI SC on SPI crankcase breather
Turbo122s
Member #: 12043
Santa Rosa, California, USA
I have just installed a supercharger with EFI on my SPI and it is running great. Currently I have just a little filter on breather that mounts to the transfer case and venting to atmosphere. This is already very close to my air filter. I am thinking about just connecting that breather line to the air filter itself. The SC is already sucking in the fumes.
Any issues with doing this? This would all be pre fuel and pre forced induction.
I know that I can do a catch can. Being an SPI there is already a lot going on in the engine bay. There is no MAP. So no need to worry about getting that all junked up. Just trying to avoid adding 1 more thing to the engine bay
Steve220
Member #: 11017
Shropshire
Oil, be it mist or fumes, will lower the octane rating of the fuel.
Turbo122s
Member #: 12043
Understood on the octane issue. Other than that are there any other issues?
NDT
Member #: 11884
Can't think so. Isn't that how most modern cars are plumbed, blow by gases into the intake?
Incidentally, what ECu are you using to drive your injection?
Are you using the existing SPI throttle body?
Will it flow enough fuel?
