| Home > Help Needed / General Tech Chat > Question on starter motors & flywheel rings | |||||||
307 Posts Member #: 11231 Senior Member |
30th Sep, 2022 at 07:37:15am
Hello All,
30th Sep, 2022 at 08:36:39pm
How many teeth does the ring gear on the flywheel have? 129?
109 Posts Member #: 10368 Advanced Member Australia |
9th Oct, 2022 at 10:47:28am
Hi Barrieri, I have had similar conflicting/confusing advice ( to me anyway).., ,so i am no help with the number of teeth. I had a Med lightened ( pre-engaged type) flywheel and found I needed a 2mm spacer to back off the starter motor. it could have been my flywheel sitting down the crank taper or the flywheel or the starter,, so not knocking the product at all,,,, just pays to check the ' bendix throw |
9th Oct, 2022 at 12:30:07pm
Sounds like a good excuse to buy a lightweight starter motor with the correct pinion. Pretty sure for the pre-engaged it’s 11. If your using one you have perhaps put the flywheel in a vice and see how happily they mesh. 10 teeth is probably more correct than 9. On 7th Oct, 2010 5haneJ said:
9th Oct, 2022 at 07:34:25pm
Correct me if I'm wrong but don't the A series and A+ flywheel ring gears have different Tpi so will grind themselves to dust over time? Own the day
976 Posts Member #: 3228 Post Whore North of the Netherlands |
10th Oct, 2022 at 01:20:03pm
You are right; A series and A+ series flywheels and starters should not be mixed.
On 9th Oct, 2022 Mr Joshua said:
Correct me if I'm wrong but don't the A series and A+ flywheel ring gears have different Tpi so will grind themselves to dust over time? Dazed and Confused.... |
