| Home > Help Needed / General Tech Chat > K1100 Oil returns | |||||||
174 Posts Member #: 9128 Advanced Member |
21st Jun, 2023 at 09:18:38am
I've search and searched but can't find anything on the oil returns in the head. I've drilled the one hole through the cam bearing saddles on the induction side. But Gregg on his site talks about both sides, so has anyone drilled the exhaust side and if so did you go in just above the oil way that's cast into the head ?
Edited by DILLIGAF on 22nd Jun, 2023. |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd Jun, 2023 at 10:05:49pm
I've not drilled either?
22nd Jun, 2023 at 11:37:50pm
Interesting Shane thanks for responding, you've not had any problems with oil pooling up in the rocker area. Doesn't seem like anyone else has done it either. |
23rd Jun, 2023 at 07:12:20am
I suppose although it ponds between cam and cam bucket there is a void below which drains the oil around the spring/guide. On 7th Oct, 2010 5haneJ said:
23rd Jun, 2023 at 10:09:44am
Good to know nobodies had any bother, must admit I didn't think there'd be enough drainage around the buckets.
23rd Jun, 2023 at 10:35:14pm
24th Jun, 2023 at 03:36:14pm
Looking at the head again on the exhaust side three sections have a direct drain for the oil, the second section and the one furthest away from the cambelts doesn't.
