| Home > Beginners Tech > MG Metro heat exchanger hose connections | |||||||
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
20th Nov, 2023 at 07:10:49pm
Hi there, as far as I know the MG Metro and Metro turbo had an oil/water heat exchanger that was mounted to the oil filter. I am planning to install such heat exchanger but I dont know the proper locations where to connect the water hoses to the engine system. Of course I want to retain proper function of the interior heater. So, anybody who knows the two points where these hoses are linked to the colling system of the engine?
20th Nov, 2023 at 09:27:16pm
I thought that was an oil stat, that bypassed the oil cooler when oil temp was low. Own the day
21st Nov, 2023 at 03:01:43pm
Sorry Mr Joshua, its not an oil stat. It is the device like a small donut screwed in between the oil filter and oil filter holder. This also needs to be connected to the water cooling system. My question is where to connect these hose to the cooling system in order to make it work well and maintain the interior heating. I hoped somebody with a genuine MG Metro could tell me straight away ( fiy: I will use this heat exchanger only to be sure the oil warms up well, not to cool. Currently this is for an A series engine in an Austin A40 Farina. They hardly get the right temps even when racing the car. No gears in the oil to create friction, sump sticks down well in the wind.)
21st Nov, 2023 at 07:10:59pm
Very interesting I've broken many mg engines and have not come across what you have I've only ever come across the Mocol unit. Any chance of a picture. Own the day
174 Posts Member #: 9128 Advanced Member |
21st Nov, 2023 at 07:33:21pm
All the MG defo had the oil to water cooler, or at least all the ones I've owned and broken have. It's not usually used in a Mini as it requires the front subframe cross member modifying. Plus it puts more heat into the minis already struggling cooling system. |
22nd Nov, 2023 at 01:40:44pm
Type of heat exchanger is quite similar to Ford :
22nd Nov, 2023 at 05:09:51pm
Im thinking it has to go in series into the same circuit as the inlet manifold.
Edited by Mr Joshua on 22nd Nov, 2023. Own the day
22nd Nov, 2023 at 08:14:00pm
That makes sense Mr Joshua! Curious where the heating pipe of manifold will be connected to the rest of coolant circuit.. gracias! |
23rd Nov, 2023 at 04:58:28pm
Mpi bottom hose and the sandwich plate. Or use the heater take off above no.4 without the sandwich plate. In both cases you will need to split the flow with each circuit returning into the two returns in the bottom hose. I adopted the heater take off method to help scavenge the hot water from around no.4 Own the day
26th Nov, 2023 at 08:59:56pm
Thanks , I will study the routings for the solution with using the heater take off. |
108 Posts Member #: 9182 Advanced Member |
28th Nov, 2023 at 05:54:28pm
That intercooler was fitted to the MG Metro but not the MG Metro Turbo. I'm a little confused by your post, are you trying to cool the oil or heat it up for racing? |
