Home > Introduce Yourself > Another turbo build
robsturbo
Member #: 12343
mid devon
Hi guys ive managed to get hold of a 2000 mile med turbo engine and all the metro turbo bits on it already in a rusty mini, its missing its distributor and im struggling to figure out which one i need as i dont have the metro ecu or boost solenoid either..
Any help would be great
Yo-Han
Member #: 3228
North of the Netherlands
Welcome to the forum.
Have a search for Megojolt ignition or something simular, it's affordable and much better then original distributor.
I think most have ditched the exu and selenoid anyway.
Dazed and Confused....
You don’t need the standard ECU and solenoid, this was just a device to control the boost, adjusting it above/below 4,500rpm. It had no bearing on the ignition.
As suggested above, you’re much better off buying a fully programmable ECU to control the ignition, this is far superior to an old clockwork distributor.
Phil.
robsturbo
Member #: 12343
mid devon
Thanks for the advice guys, now onto the next set of questions lol
Been looking at megajolt set ups and im confused when it comes to the options list, its asking what ecu version i want i guess that would be map sensor ? as i don't have throttle position sensor on the carb setup.
https://www.trigger-wheels.com/store/contents/en-uk/p98.html
Heres the one i was looking at is this correct ??
Also do they come with any base map to get you running or does it all need to be set up professionally
Sorry for all the questions i just want to get it right is all
rob
Yo-Han
Member #: 3228
Yes you would need a MAP version.
I think there are some ignition maps to be found on this website; have a search. Dependent on your build probably best to spend a bit extra and get it properly set up.
