Home > Help Needed / General Tech Chat > Is a heated inlet necessary ???
robsturbo
Member #: 12343
mid devon
Evening gents
Is a heated/cooled manifold needed on a metro turbo inlet, its just i never use my car in cold conditions and never in ice or snow, ive read up about some peoples carbs have frozen up with out it..
My will never freeze as never out in the cold, but does it need to be cooled with coolant ? or is it just to stop icing up carbs in winter time..
Many thanks
Hi, it never cools. As you say, it’s to heat the manifold to prevent icing. You can get rid of it.
Steve220
Member #: 11017
Shropshire
On 28th Feb, 2024 robsturbo said:
Evening gents
Many thanks
Carbs can freeze over in the summer, tends to be more common then due to the moisture in the air. Very common on piston aircraft. When it comes to the mini, i doubt it'll make any difference as the inlet manifold is right next to the exhaust manifold.
robsturbo
Member #: 12343
mid devon
Thanks guys for advice, certainly makes a tidier job with it all gone..
