Home > Help Needed / General Tech Chat >
jamesRs250
Member #: 12240
Kent
On 19th Jun, 2024 lee.pb said:
80 kPA is still within the normally aspirated range as 100kpa is throttle wide open.
Anything above 100kPA is boost.
Yeah I have a working map sensor now. So the KPA is higher on the graph now. So I can now get the ignition map set up properly.
I'm not sure what this stutter or misfire it get sometimes.
