| Home > Help Needed / General Tech Chat > Radiator shroud better radiator idea's | |||||||
83 Posts Member #: 12240 Advanced Member Kent |
7th Mar, 2025 at 08:55:17pm
Im currently using a fletcher radiator I don't have any over heating problems but I would like to get the cooling system/ radiator a bit more efficient. The temperature is slightly higher than when my car was N/A It does gets slightly hotter in traffic. I have added a electric fan in the wing aswell.
7th Mar, 2025 at 09:19:56pm
If it isn't overheating, then what's the problem ?
7th Mar, 2025 at 11:31:25pm
On 7th Mar, 2025 stevieturbo said:
If it isn't overheating, then what's the problem ? But most basic rules are, ensure only cold air into the rad, and try and help hot air escape. If this means ducting and shrouds in suitable locations, then yes. Well it's on the hotter side really 85 degrees gets to 90ish in warmer days in summer. Runs fine at that temperature. |
