Home > Technical Chat > FAO injection peeps
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Would knowing the cam timing figures of a std MPi be any good to you?
Alex
AlexF
if you have them, can you post them?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I haven't
but I'm stripping a MPi at the moment...
and thus can!
Alex
AlexF
When you take the figures, can you repeat for the siamesed cylinders - IE 1&2 or 3&4.
One theory on the MPi is that the inlet lobe is advanced on the inner cylinders and retarded on the outer cylinders - basically reducing the overlap between the two valves being open at the same time (which share the same inlet port).
This would be VERY good information to know... *wink*
Although from what i've heard of MPi's, the cams may well be shagged. Then again, it's usually only the peak of the lobes that gets damaged - not the start ramp *happy*
Edited by turbodave16v on 6th Oct, 2005.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
This engine is in very good nick... the rocker pads look used but you can't feel the wear...
So hopefully its not worn out.
I was planning to get the timing figures for ALL the lobes, just so as not to mis anything.
Alex
AlexF
good good!
