Home > General Chat > revs drop
mr t bo
Member #: 78
milton keynes
hi all,
I managed to finally get my car started today i was going to take it up the road untill i pressed the clutch down. The revs dropped by about 150 - 200 rpm i am using a grey dia, paddle plate etc. I have never had this happen before or it may be that i was paying attention this time. Has anyone else had experience of this ?
jonny
Classic symptoms of a grey diagrpham and old thrust washers......
The weight of the clutch spring puts excessive load on the thrustwashers, gradually these wear until they are knackered.
Cue- picture from vegard..........
As Tom says - it's starting to happen. Pull it apart now, and chances are you will just be able to replace the thrusts. Leave it be for a long time, and you'll be getting the crank re-ground.
I agree 100% of above, if you leave it too long you will destroy your crank.
this clutch Scenario! needs to looked at indepth & put to bed once & for all
when the garage is sorted there will be more time to look at the matter with input from all peeps! & chuck a few quid at the problem*wink*
Dangerous
Member #: 417
Is there better material or coating fo thrust washers I wonder *wink*
I've spent 20 hrs this week designing a clutch, and have come round in a full circle. Problem i'm having is that i'm trying to make it easilly manufacturable - ie laser / waterjet cut flywheel disc incoroporating the ring-gear; Verto centre for the flywheel, off-the shelf (tilton/quartermaster) cover - or at least diaphram spring, STOCK driven plate (most importantly), etc...
I've got a solution, but it could weigh in at the same, if not slightly higher inertia than a steel ultra-light... But it would have a 260lb ft torque capacity - even when the driven plate is worn right down past the rivets (unlike the stock item) AND have a release load of only 80% that of an orange diaphram...
*wink*
TBH Dave I would happily sacrifice a bit of light-ness (is that a word!?) for a reliable clutch that isn't going to constantly lunch the thrust washers......
dan
Member #: 93
you could have quite a few potential buyers dave if you crack this!
indeeed! Well done dave, keep up the good work!I don't mind it being a bit on the heavy side. Could it not be made out of ally and then have a liner bolted in, or maybe sprayed on.
keep up the good work dave
this is whats needed for the A series for some time
i bet mr dodd of minispares would be intrested
or one of us over hear could make these up and turn them out 4 u
ie to all the mini speed shops!
whatever you should be quids in.
ben:
mr t bo
Member #: 78
milton keynes
thanks for the advice guys, only thing is that these are brand new thrusts. i have spoke to a few people and they said that their car did it on start up but it then settled . it has worried me dont want to distroy bits in a new engine
ditto
jonny did you fit the new thrusts? Did you check the crank end float?
i best lay off the pies
you say slightly heavier than the steel ultra light, but how many of us here run lighter than the ultra light?
mr t bo
Member #: 78
milton keynes
yep all new bearings and thrust everything is brand spanking new. the end float was also checked worked out at 6.5 was told this should be spot on
6,5 thou inches?
That is WAY too much. I aim for 2-3
Tom.. No pictures this time *wink*
