Home > Help Needed / General Tech Chat > Part Numbers
Having spent 3 hours with the search function and google, I'm going to have to give in and ask for help.
First I need help identifing a turbo, I beleive it is a T3, but all it says on it is Garrett BCC AR 42 on the compressor housing. I'm guessing that AR 42 reffers to an area/radius ratio of 0.42, yes, no?
Second I've got a couple of dizzys, one has 41882A under the vac take off, and looks like a bog standard mechanical dizzy. The other has no numbers on the dizzy, but when you remove the dizzy cap the guts resemble a 59 DM4 dizzy pictured in the Metro Haynes Manual, however the external amplifier module is made by Ducellier and has the following part number 521007 D or it could be 521607 D (the paint has been scratched)
If any one could help with either of these it would be greatly apprechiated.
