Home > General Chat > undersize crank
Dangerous
Member #: 417
I have a hardend turbo one .00005" to .0001" undersize(on std)on mains still round and un marked
Worth using*oh well*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
re-gringing makes it no better than a std crank...
alex
AlexF
Why? It's suspected the material was different between the 6232 and the 6581 - You don't have a different forging number for the same material and/or same forging moulds.
Has anyone out there got any knackered cranks with the above numbers? As if I can get a sample of both, I can take them to work and have them spark tested. This gives composition etc of the steel used, so would give a definative answer once and for all to this question of material specs.........
Dangerous, i woulld say that was perfect,
carl
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I was under the impression the turbo cranks where "treated" rather than high spec material!
alex
AlexF
That's what Viz said - but it seems mad to take out a different Forging number for a different heat-treatment process - if this was the case, you'd stamp/spark the number.
Anyone got any dud cranks - I'd love to know the metalurgical differences once and for all!
Tom - make a new post asking for donations and get an admin to 'sticky' it!
Dangerous
Member #: 417
carl
Yep it's just a tad little on the cam end main,so will prob use it rather than go -.010"
On job I do at work is a repair for dowty,looks a similar coating,when I prep th job its only about .002"/.003" thick so is ground with a diamond wheel to remove as a grit wheel won't touch it
