| Home > Help Needed / General Tech Chat > Block | |||||||
![]() 71 Posts Member #: 529 Advanced Member Stoke-On-Trent |
12th Oct, 2005 at 10:40:27pm
Having a sort out and got a turbo block which looks like it has liners in. |
13th Oct, 2005 at 06:21:57am
dont bin it, you can rebore to plus 20 thou so i under stand, some people have used them and i dont think they had any probs,
13th Oct, 2005 at 08:33:04am
as hogy said, don't bin it! On 15th May, 2009 TurboDave said:
13th Oct, 2005 at 04:19:46pm
I'm using a linered block. Will have to see how it goes.
13th Oct, 2005 at 04:27:27pm
I was speaking about this today to carl austin, both agree it should be ok to use, the material used in the liners is better than the block, so should be better. as long as you don't go any bigger than +020 On 15th May, 2009 TurboDave said:
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
13th Oct, 2005 at 04:28:54pm
i think mine's linered too? |
13th Oct, 2005 at 05:13:32pm
Right i'll keep the block.
13th Oct, 2005 at 07:03:27pm
you can also reliner it i was quoted £100 for removing, refitting and boring the liners to suit which i thought was supurb, then about £80 for liners and hey presto new blockish.
14th Oct, 2005 at 03:09:14pm
hmm i woulnt mind a linered on for my next engine then |
14th Oct, 2005 at 03:36:19pm
The reason hogster states above is the reason I used a linered block, as I have had other expensive mods carried out, so 'hopefully' if needs be I could have it re-linered without having to have the other m/c work done again.
14th Oct, 2005 at 05:14:11pm
If you had a lot of mods done to a non linered block and the bores went,then surly you could have liners put in that
15th Oct, 2005 at 09:39:44am
On 13/10/2005 16:28:54 AlexB said:
i think mine's linered too? Oooooooohh no it is'nt!.......Behind you! On 21st Jan, 2011 fastcarl said:
15th Oct, 2005 at 04:46:25pm
im not sure of the od of the liners but i think if its still about +40 then they wont be a problem i have asked gary loads of times for the od of the liners but as usaul he cant be arsed always looking for them bigger bunches of bannanas |
17th Oct, 2005 at 07:38:46am
Factory liner OD is 73,09-73,106 mm. (source AKM6353 factory repair manual) |
17th Oct, 2005 at 10:09:55pm
So if you were +.060" (2.840") you could go out to liner size 2.878" are be back to standard bore
Edited by Dangerous on 17th Oct, 2005.
20th Oct, 2005 at 08:00:30am
thats a buggerv then as i had a block sitting in my garage which when bored to 73.5 mm went through the water jacket because of corrosion.
20th Oct, 2005 at 09:09:01am
ACDODD wrote somewhere that a linered block could be used in 040 form if it was a low performance engine. On 13th Jul, 2012 Ben H said:
20th Oct, 2005 at 10:00:06am
whats the point in a low performance engine? |
20th Oct, 2005 at 10:23:03am
To make it last :)
