Home > Help Needed / General Tech Chat > dropping the compression ratio
jow
Member #: 711
hey ppl am a newbie wanting boooost.im on a limited smallesh budget and just got a few questions to ask.if i got my hands on a T2 turbo and a manifold for it to fit my 998 in what ways could i then drop the compression ratio, that is if i need to at all.also would i have to upgrade the fuel pump aswell? thanks
Check your engine number against the list on the Manchesterminis.co.uk site (under 'technical') and find the CR of your engine.
T3Tone
Member #: 252
Sunny suffolk
The standard mechanical pump is no use for turbo conversion, you need an electris metro turbo pump or something similar.
-MINI CLUBMAN 1380 TURBO-
Richie
Member #: 628
getting the pistons dished could be pricey and would mean a full rebuild (which i would do anyho if fitting turbo) but getting the head ported out around the valve areas brings it down. as dave says check the numbers, which you may be able to corroborate wth a compression gauge if i am right (rarely)
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
