Home > Show Us Yours! > Progress of my turbo mini refit
sam_shelton
Member #: 251
Nottingham UK
This car has been turbo'd for a while now but this is the current state of progress with the refit. It has had:-
New inner wings, heelboard, complete floorpan, bootfloor, rear quarters, mk1 conversion panels, rear panel, new step sills, and will have new rear bulkhead and parcel shelf before I finish.
I will also be fitting a full weld in cage. Both rear arches have been tubed to accomodate my 13x8.5 inch split rims. I know what everyone will say, that they will be crap for acceleration and handling, but I think they look the muts nuts!!!
lanxter
Member #: 396
sheffield/rotherham
v nice mate its gettin there well done, can see your putting effort in
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
that roll cage looks dangerous *wink*
alex
AlexF
Looks a very thorough rebuild.
I'd be checking wheel bearings very often when you start driving it though as those wheels will be very hard on the bearings. Also make sure the rear bearings are the later taper roller type (stronger) and not the ball type.
sam_shelton
Member #: 251
Nottingham UK
Yes it is a pedestrian friendly roll cage! Not sure what bearings are on the back, I havn't checked actually. Its only gonna be a trackday/sprint car and the occasional road outing so the milage should be pretty low.
Cheers for the comments
sam
hell fire, thats some work
can you pm me more details of how you did the full floor pan please? i want to do my van and im going to put one of the complete florrs (inc heelboard) in, it also needs the bottom 3" of the side panels doing, and i see that you have done your side panels too.
did you brace it up as seen, replace side panels then do the floor?
Richie
Member #: 628
it will look the dogs baalls mate ! i used to have a set of those wheels i can recomend the car in red (peugeot red....it looks wank on peugeots but mint on minis !) sorry about pic but was taken by me phone (WANK)
Edited by Richie on 16th Oct, 2005.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
sam_shelton
Member #: 251
Nottingham UK
To be honest it has been a bit of a nightmare because as I replaced one panel I uncovered rot on another. I initially replaced the inner wings and lined them up the existing floor. Then I replaced the step panels each side. I welded in the bracing and put the cross bars across. I used 4 axle stands to stand the shell on and then replaced the heelboard. Then I cut out the floor and assembled the new one ie welded the rear subframe panel to the floor panel and then welded it into place.
I then replaced the rear quarters and then the rear panel.
In hinesight I would not have repaired the shell and would have just reshelled the car but by the time I had made that decision I had already spent a fortune on panels and put in loads of work.
My tip for doing this type of work is use genuine panels as the fit is usually spot on and repro ones usually are miles off.
