| Home > Help Needed / General Tech Chat > Top adj hi/lo allan key size | |||||||
17th Oct, 2005 at 03:39:40am
Any idea what size allan key they use on the type that adjusts through a hole in the large front subframe mount bolt
17th Oct, 2005 at 04:20:07pm
Pretty sure it's 3/8ths. On 17th Nov, 2014 Tom Fenton said:
17th Oct, 2005 at 04:45:37pm
I've drilled the bolts to 9.8mm to clear 8mm key The thread is 18.8mm and the bit above that is 17.9mm
17th Oct, 2005 at 04:49:07pm
I thought the original type hilo's were used on the earlier cars that used the solid mounted subframes, attached by the towers by 2 off 5/16" bolts. This left a big hole through the middle, usually plugged up with a grommet, but perfect for access to the hilo adjuster.
17th Oct, 2005 at 06:38:47pm
Advantage is that you don't have to lift the car off the scales to adjust...
17th Oct, 2005 at 06:47:16pm
Jims got it done on his car,I thought he was taking wieght saving a bit far drilling the bolts
17th Oct, 2005 at 08:12:09pm
minispares used to sell drilled out subframe bolts Crystal Sound Audio said:
18th Oct, 2005 at 09:15:17am
I drilled my bolts out on the lathe, as dave says, it makes it much eaiser when doing the corner weights.
