Home > Help Needed / General Tech Chat > megasquirt
roberto
Member #: 128
Just Registered!
hello,
bought a megasquirt the other day.. vers 2.2
i,m going to run the EDIS setup
need some help with conecting it to the ( db 37 connector)
if i read the sceme correct 7.8.9.10.11.19 are ground. 28 is +12V
24 on the connector is pip signal.
but where do i connect the saw signal?? and shield??
hope u guys can help me out
tnx electro-noob
Edited by roberto on 18th Oct, 2005.
AllanMcD
Member #: 414
Dalbeattie Scotland
30 is for saw (if your unit is set up for edis)
shield just runs to eath it is the foil that shields the wires from interferance
you dont need to earth all 7.8.9.10.11.19 just use a couple.
Hope this helps
Allan
http://www.rabdunn.co.uk/
Mike
Member #: 107
Sunny Sussex
version 2.2 MS's need modifying before being able to use EDIS, are you using EDIS roberto?
For info on the mod, see http://www.jsm-net.demon.co.uk/megasquirtnedis/hardware.html
