Home > Help Needed / General Tech Chat > Another engine...
mini300bhp
Member #: 653
Cambs
I got an engine off ebay the other day. Just wondering what you lot think?
(1)The head is vmax stage5 race with 36x32mm valves, 30cc. Any good? Pistons are omega 15cc, what boost can I run?
(2)It came with a 4speed SC CR syncro box. Will it last?
(3)The crank has 12G1505 and DH38AW on it. What is it from?
(4)The rods have 12G4114/5 A 27 on them. What are they from?
I'll be happy with about 180bhp out of this if posable, will the bottom end hold up?
Thanks
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
Why would you buy that, you told us previously that you had a full spec engine already??
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5936
mini300bhp
Member #: 653
Cambs
..........which is too expensive to fuck up on the road. So I got this.
What you gonna do with the other one, use it as a door stop ? *wink*
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
come on Phil you know it would be completely impractical as a door stop, Its going to replace the coffee table!
mini300bhp
Member #: 653
Cambs
Sprints, hill climbs, 1/4 mile. Want to do extreem mighty minis with it as well.
Anyway, anyone know about this crank&rods on not?
Dangerous
Member #: 417
http://members.home.nl/mmarx/mini/cranks.htm
Crank id
If you leave a bit of there is more
Edited by Dangerous on 19th Oct, 2005.
mini300bhp
Member #: 653
Cambs
Whats a turbo crank?
cam6232 or cam6581
mini300bhp
Member #: 653
Cambs
Looking at the chart mine is a na 1275 crank. Do you think it will hold up?
giallofly
Member #: 164
The Stig..
Newport Pagnell
I never spotted anything Ebay like that?...So you want an a road car that you you will hillclimb,sprint,drag race and do xtreme mighty mini!..sounds like you are gonna be a busy boy!
JF..........
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
cool come and race with me!
Alex
AlexF
have you got any more photo's of your car?? it looks the nuts!
Who did the 4 bolt centre main on your other engine then? I have not seen photos of any other ones done, the one on my engine looks like this-
Is yours stepped as mine is, towards the outer pair of bolts, or is it flat all the way across??
Did you get the outer caps done as well at the same time?
I am also interested in your rods, where did you source those from, I did a bit of investigation into uprated rods but could not seem to get any reliable info.
Dangerous
Member #: 417
What's that black bit behind the oil pump *surprised*
magnetic trap thingy ??
mini300bhp
Member #: 653
Cambs
www.arrowprecision.co.uk
Center main looks same as yours. Got mine from minispeed.
On the back of the oil pump? It is just the steel backplate?
giallofly
Member #: 164
The Stig..
Newport Pagnell
So who line bored it?
Dangerous
Member #: 417
no straight down from the left hand cap*indifferent*
Water drain plug! I see what you were looking at now!
giallofly
Member #: 164
The Stig..
Newport Pagnell
http://cgi.ebay.co.uk/Mini-Turbo-engine-Mo...1QQcmdZViewItem
i stand corrected.....
£1120 for a seized engine?
Full race cam?
Great purchase!
yes seized and full race cam, hmmmm,
also 175 lift rockers??
each piston has 15cc dish for more compression!!!! WTF!!
Cooper S rods?? maniflow exhaust manifold!!!????
someone who has built an engine like this from scratch should know better!
SumpNut
Member #: 28
i dont quite see how it can seize without being run?
mini300bhp
Member #: 653
Cambs
I only got it for the head, pistons, turbo, carb and gearbox which is all unused. I striped it all down, and it a aint seized anyway, but I don't think I'll use the block as its a linned one so thats going in the skip tomorrow along with the crank.
Fair enuf!
I'd offer the block/crank back on ebay - someone will have it - recoup some of the moneies you spent!
Edited by turbodave16v on 20th Oct, 2005.
