Home > How To > Clutch cover removing idler gear outer race easy!
metroturbo
Member #: 989
North Yorkshire
How do you work out where to drill the holes? I can't find a decent datum to measure from.
metroturbo
Member #: 989
North Yorkshire
Anybody?
pretty much just guess,
can you reference a distance to a bolt hole?
metroturbo
Member #: 989
North Yorkshire
I've got nothing better than a steel rule to measure with and there isn't a bolt hole that I can get a good measurement from on both sides. Best guess might be my only option.
Edit: Actually I'm talking bollocks, I might be able to get a reasonable measurement with my verniers.
Edited by metroturbo on 19th May, 2010.
metroturbo
Member #: 989
North Yorkshire
Managed this with a bit of guessing and bit of measuring. Worked great, the bearing knocked straight out with no messing about.
