Home > Technical Chat > timing figures
Mike
Member #: 107
Sunny Sussex
found these figures on the MSEFI forums, are they correct?
standard 1300 turbo mini (12HD)
9-10 static
9-13/2360 (no vacuum)
11-16/2880 (no vacuum)
15-19/5600 (no vacuum)
vacuum range 22-26 degrees advance
start at 20 mbar
end at 213 mbar
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hmm the sound a bit low to me...
from 8ish degrees at idle my turbo dissy use to avance to 28ish degrees by about 3500...
I didn't run vac advance.
Alex
AlexF
