Page: |
Home > 998cc > Advice on 998 Turbo please | |||||||
![]() 282 Posts Member #: 616 Senior Member Birmingham |
30th Oct, 2005 at 05:20:50pm
Hello all, Edited by AlexB on 7th Nov, 2005. |
30th Oct, 2005 at 07:47:18pm
Turbo dizzy/or mod yours or mega jolt etc
30th Oct, 2005 at 08:40:07pm
There has been loads and loads and loads of threads and discussion on this subject, use the search button and read back through all the old posts.
31st Oct, 2005 at 08:30:36am
I think you're on the right lines too.
31st Oct, 2005 at 02:52:03pm
Unskimmed head to keep compression down!! I would have it skimmed if its origin is unknown and if CR is a problem you could always have the chambers machined out to lower it. -MINI CLUBMAN 1380 TURBO- |
31st Oct, 2005 at 11:23:04pm
On 31/10/2005 14:52:03 T3Tone said:
Unskimmed head to keep compression down!! I would have it skimmed if its origin is unknown and if CR is a problem you could always have the chambers machined out to lower it. A lot of the 12G295's out there have had a LOT of meat skimmed off them to allow them to be used with dished/flat top pistons. The original 998 Cooper engines they were fitted to, had raised crown pistons. Therefore, this large amount of skimming is needed to get sensible compression on an engine with flat or dished pistons. By getting an original "unskimmed" example, you still have this volume, which is useful for CR purposes. But as with any head, a LIGHT flash skim is always advisable to get a flat mating surface. I think this is what was meant by the phrase unskimmed head! ![]()
1st Nov, 2005 at 11:08:29am
Has anyone run a 12g940 head on a 998 and turboed it?
1st Nov, 2005 at 11:48:36am
Yes I run a 940 on a 998 with a turbo.
Page: |
