Home > General Chat > wots it do
ben doodar
Member #: 595
stoke on trent
ive got a new rebuilt engine with a kent cam in a ported n polished head a 5gt turbo intercooler and a -31 acuator running about 15psi wot power does any1 reckon it will be. also my mechanicking mate says. if i have the pistons skimmed ill get more from the engine without having to run as much boost. is this true
I reckon 140 to 160 banans easy.
Not sure about the piston mod. All it would do is reduce the CR allowing you to run MORE boost.
Wil
ben doodar
Member #: 595
stoke on trent
no way i was expecting bout 110bhp very tops. even more inspired to get my finger out now. i think ill have the pistons done for an extra 50 quid. mite be able to run a bit more boost through it. also ive seen for sale hi boost carb needles. and hi boost carb springs. i guess i need them so is the gearbox going go boom after a short time.
Don't bother with the high boost needle, but the spring is worth having.
Once running get it to a rolling road where the needle can be properly profiled.
As you are local (to me anyway ish) I suggest using Mikeaniacs in Congleton.
You'll find their contact info in the rolling road thread on this forum.
Wil
ben doodar
Member #: 595
stoke on trent
i no mikeanicks hes about 5 mins walk away from my work. i work at the new halfords in congleton. if ur ever passing ull have to pop in for a chat
Pass through Conleton every day (twice)
ben doodar
Member #: 595
stoke on trent
im in till 5.30 today and in till 8.15 on friday if u aint got anything better to do than chat about minis ull have to pop in. ben
Skimmed pistons equals crappy combustion. Less CR but the ability to run high boost remain the same. Loose-loose situation.
ben doodar
Member #: 595
stoke on trent
so u wudnt bother ive heard from so many people its a top mod to do. i know a lad with a 5gt turbo thats bout 275 bhp wud u not reckomend it
i wouldnt recommend it at all. better to go for bigger chambers or bigger dished pistons to run more boost *smiley*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
yeah well more than 110bananas lol, i got 111 out of my standard engine with 9psi and a higher boost spring/needle.
