| Home > Help Needed / General Tech Chat > FLIP FRONT | |||||||
102 Posts Member #: 155 Advanced Member |
6th Feb, 2004 at 10:06:28am
HAS ANY ONE FITTED A FIBRE GLASS FLIP FRONT ? |
6th Feb, 2004 at 10:29:58am
Yep I've got a fiberglass front, I got it from Mini Spare and it's fine.
291 Posts Member #: 48 Senior Member Leicester |
6th Feb, 2004 at 11:21:14am
I'd advise a steel removable front with opening bonnet |
6th Feb, 2004 at 01:21:51pm
The rust problems associated with a normal front are usually build up and lack of access to the relavent areas. Id recommend a steel flip front as they look better and its harder to tell the car has one fitted. Rust isnt a problems as it can cleaned and protected well in the areas that matter as access is vastly improved. (back of a-panels, under scuttle etc.) |
6th Feb, 2004 at 05:15:47pm
I've heard good things about these guys for flip fronts.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
103 Posts Member #: 31 62horses at the wheels and counting |
6th Feb, 2004 at 09:31:07pm
I have a full steel flip and removabel front.
![]() 323 Posts Member #: 41 Senior Member |
7th Feb, 2004 at 09:01:29am
i have a steel flip front too, but im going back to a normal front, i.e weld the outer wings in place, no inner wings and a removable bonnet, its been nice having the flip front as other mini owners are usually impressed by it, but i think it will be easier to do oil checks etc with just a removeable bonnet and removeable grille. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
19th Jan, 2005 at 12:21:08pm
does anyone have detailed pics of exatly where to cut?
19th Jan, 2005 at 12:35:53pm
pretty sure ive got some photo's of my mates at home dude, i'll have a check later and email em you if you want? On 20th Oct, 2015 Tom Fenton said:
19th Jan, 2005 at 12:40:17pm
y please, borrowing an air saw soon, decided not to pay a bodyshop a fistfull of cash so i'll do it myself for pure satisfaction. Still need someone to weld the box in tho, been a while since i welded! btw, has any1 actuallty come across a bulkhead thats failed cos of the box?
19th Jan, 2005 at 02:11:13pm
http://www.manchester-minis.cwc.net/techni...flip_front1.htm On 17th Nov, 2014 Tom Fenton said:
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
19th Jan, 2005 at 03:43:06pm
i had a flip front and all i have to say about it is...
19th Jan, 2005 at 04:54:35pm
i plan to use the existing front end not a huge fibreglass fan tbh.
19th Jan, 2005 at 08:27:31pm
Very good to have a flip front. It is best to have a removable bonnet as it is a pain checkin the engine oil etc. Even worse when you think you have a problem and ya sat on the hard shoulder of tha M6!! |
19th Jan, 2005 at 08:29:13pm
lol y, m8 of mine has a one piece front, pain in the ass!
20th Jan, 2005 at 08:58:59am
ive got a fibreglass front and would like to have a steel one as said previously there will still rust as per normal fronts.
148 Posts Member #: 98 Advanced Member Slovenia |
20th Jan, 2005 at 09:30:43am
i like my flip front very much!
20th Jan, 2005 at 06:54:50pm
Are the ones with the "a "panels on them any good?? I used to have a normal one years ago and didn't like the join and cutting the arches in half.
21st Jan, 2005 at 08:48:58am
thats were ive got to fit mine, the one small small problem with flip fronts is you tend to have physicaly less room in the front area of the engine as you have to be carefull nothing fouls on the front when you close it unlike a normal front you can jam stuff in as you only have to close the bonnet (if that makes sense).
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
21st Jan, 2005 at 02:23:39pm
i'd like to see some pics of some flip fronts fitted that include the 'a' panels in the moulding
16th Feb, 2005 at 11:42:17pm
Found it !!
16th Feb, 2005 at 11:49:09pm
3rd Sep, 2008 at 07:49:20pm
On 19th Jan, 2005 TurboDave said:
http://www.manchester-minis.cwc.net/technical/flip_front1.htm Pooh the link has stopped working :( has anyone got a copy of it? Only dug up this post as a chap in my local club was after some info on how to fit a flip front and this was the best guide I've ever seen. Isambard Kingdom Brunel said:
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
3rd Sep, 2008 at 08:36:23pm
mine is a metal removable front see my build thread if it helps
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
3rd Sep, 2008 at 09:54:06pm
Found the guide:
