| Home > Help Needed / General Tech Chat > Pressure drop over the carb? | |||||||
263 Posts Member #: 115 Senior Member Austria, near Vienna |
1st Nov, 2005 at 06:47:30pm
Hi, Bimmer Twinky headed and turboed A-Series:
1st Nov, 2005 at 07:50:06pm
I'm sure it was 1.5psi when i measured it. VERY long time ago though... On 17th Nov, 2014 Tom Fenton said:
1st Nov, 2005 at 07:54:30pm
ahh, now then - I answered this on the lines of pressure drop across the restrictor in the plenum...
2nd Nov, 2005 at 09:50:50am
I measured 1.5 as well on a std ish engine...
AlexF |
2nd Nov, 2005 at 03:17:22pm
Were you refferring to a pressure drop across the whole thing - like the problem the R5GT guys have with their smallest of small carbs? On 17th Nov, 2014 Tom Fenton said:
2nd Nov, 2005 at 07:10:29pm
Yes, across the whole thing! Manifold vias plenum!
2nd Nov, 2005 at 11:23:27pm
If i had 4 inlet ports i wouldn't be on a carb - i'd be playing with megasquirt!!! On 17th Nov, 2014 Tom Fenton said:
4th Nov, 2005 at 05:42:05pm
My Megasuirt is already orderd! Measured about 0,25bar boost loss today on the dyno at 1,3bar in the plenum. Bimmer Twinky headed and turboed A-Series:
4th Nov, 2005 at 06:25:27pm
Interesting - wide open throttle i assume?
4th Nov, 2005 at 07:00:50pm
Yes, numbers are right; mesaured at WOT! Will connect my 2nd MAP Sensor to the plenum next time - so I havn't to compare a MAP against a (calibrated!) analog onboard instrument.
