Home > Help Needed / General Tech Chat > final drive
nogin
Member #: 487
westbury, wiltshire
tryed looking in my hayns manual but nothing what would a 1098 a+ final drive be cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Dangerous
Member #: 417
Depends on year and what size wheels it had fitted,whip the speedo drive cover of and count them
nogin
Member #: 487
westbury, wiltshire
sorry might have it wrong mean the ones on the diff eg big gear and small one
i also make things
Dangerous
Member #: 417
yep take the speedo drive cover off,you can then count the number of teeth on the small cog
nogin,
the BIG & small gear you refer to are called the crownwheel & pinion for the final drive.
the larger one been the crownwheel
1098's are all 3.44 as far as i know...
Gibbo
Member #: 34
If the engine is in the car, then you can make a mark on the road wheel and push the car in 4th gear for one revolution whilst counting the number of crankshaft revolutions. Not too hard if you get someone to help you!
nogin
Member #: 487
westbury, wiltshire
so should i stick with the 3.2 or go for a 3.4 for better acceleration, what speed would i be doing tops on 13 inch wheels cheers
i also make things
Nick
Member #: 154
Midlands
http://www.minifinity.com/index.php?name=U...req=getit&lid=4
use that program and work out which ratio would suit you best.
