Home > Technical Chat > list of turbo that fits mini´s??
Venom
Member #: 755
Portugal
Today i´ve fount out that my turbo still doesn´t spin freely has it should after a month full of wd40 in the bearing. Is it seized??
It moves but i must press hard on the compressor "fan" to make it TURN (not spin).New turbo comming? If so wich cars are obvious donnors? (metro turbos rare in portugal)i´m intressed in t2 or t3.
T3 if i cut the bulkhead, T2 if i go to the mirage setup. Does any body know the price of the mirage kit??
thanks
antman
Member #: 358
Snetterton, Norfolk
I believe the price of the Mirage kit is around £350. Depending on the power u want they do some good Hybrid turbos as well. Nic is the man to talk to about the Mirage setup!!
Dangerous
Member #: 417
t25 of the rover
SumpNut
Member #: 28
T25 from various nissans
T2 from renaults
Venom
Member #: 755
Portugal
hi there, t25 from nissans direct fit to manifold or some fabrication required?
thanks
Dangerous
Member #: 417
t25 same stud pattern as a t2 where it fits manifold,so would fit with mirage manifold if the turbo is the same overall size.
On the downpipe,mirage bolts straight to the turbo via 5 bolts so it doesn't really matter what shape or size the outlet is on it.
An adapter plate can be made or got of JIMSTER on here to fit a t2 or t25 to the standard metro manifold
Edited by Dangerous on 5th Nov, 2005.
as its been said the mirage kit is £350, you can run the t2/t25's which have the 4 stud fixing
a phase 2 (watercooled) renault 5 is the one to use, or you can get new hybrids from mirage
sumpnut is running a nissan t25 on his mirage setup
the mirage downpipe will fit either style (although i think there may be a few odd styles kicking around)
Star Mag
Member #: 375
Leicestershire
is the t 25 off the rover tomcat??
Dangerous
Member #: 417
I got mine of a rover ?20 2 litre 4cylinder and the intercooler,can't remember exact model
Rover 220 turbo hatch, 220 turbo coupe (tomcat), 420 turbo, 620 turbo, 820 turbo, all share the same turbocharger.
