Home > Help Needed / General Tech Chat > PLENUM CHAMBER
mini300bhp
Member #: 653
Cambs
I've seen a couple of metro turbos running without a plenum, the boost pipe goes stright into the carb.
Would this settup gain any power and are there any side affects?
Cheers.
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
antman
Member #: 358
Snetterton, Norfolk
The idea of having a plenum is so that when you are of throttle and then go back on, there is still a gulp of air there for the engine to use. I expect that you can run a boost pipe straight onto the carb, but it may be at the sacrifice of throttle response! Thats wot i was taught at College but if anyone has any other ideas?
nogin
Member #: 487
westbury, wiltshire
thought the plenum was there to make sure that there was even distrebution of pressure, if you had a pipe going into the carb you would most likely have a bend and the speed at which the air was going in would be different, the air on the outside would be going faster then the air on the inside, would give uneven fuel mix
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
mini300bhp
Member #: 653
Cambs
What about removing the restrictor ring, or would that make it run shite?
minimark
Member #: 19
newcastle
oh dear me ..... you can`t buy knowledge...
