| Home > General Chat > Coatings on ebay | |||||||
![]() 102 Posts Member #: 180 Advanced Member Northants |
6th Nov, 2005 at 10:13:53pm
Dunno if anyones seen them but here they are http://cgi.ebay.co.uk/Ceramic-thermal-barr...1QQcmdZViewItem £190 for piston and head |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
6th Nov, 2005 at 10:31:33pm
Yes i have seen it done on Mirage's pistons that are going into his engine. Not sure on how effective it will be, but seems to make sense on the pistons. Not so sure on the cylinder head front!! |
6th Nov, 2005 at 10:46:01pm
I think it must be smaltiriva type coating,that literally comes out of a spray can and cures in an oven at 150c
6th Nov, 2005 at 11:35:29pm
"david visard"...who the fcuk is he?
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
7th Nov, 2005 at 03:24:45am
I had my head coated (exhaust ports, chambers, valve heads), and just got the pistons and bearings back Friday from coating. Mains, big ends, thrust, and piston skirts got slick coatings, and the piston tops got heat reflective. How much difference will it make? I don't know. But I'm pretty sure there are some advantages. Keeping the heat in the exhaust gases will help the engine run cooler and keep the gas hot to the turbo, making for a greater differential between pre-turbo and post-turbo. That should translate to power.
Edited by Dr. jinG on 7th Nov, 2005. **************************************
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
8th Nov, 2005 at 12:56:48pm
what happens if a piece of coating comes away from the piston face.........expensive rebuild methinks
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
