Home > Help Needed / General Tech Chat > Another Question
Dicanio
Member #: 91
Hi
A bit like the guy on the other post, i thought that putting a Turbo engine in would be quite easy, but the more i read the more terrified i get. I have yet another question (and i doubt it will be my last), I have had a bit of a look at my Turbo today (had the engine stripped down a while, but have been concentrating efforts on bodywork) and it seems quite difficult to turn the turbine, i can just about move it by hand, it turns quite easily with a rachet, is this normal or should it rotate easier than this. Also had the micrometer on the shaft and there is no end float movement.
Sorry for the essay.
Carl
Member #: 95
liverpool-on-sea
you should be able to turn the shaft easily with your fingures but this is somtimes abit difficult when only one end is open if not try removing the exhaust elbow and feel it with both ends you should have no or little play in the shaft and it should turn soomtly *wink*
If i remember rightly your from worksop area, im from near gainsborough so if you ever need to take a look or need a bit of advice let me know.
Just fitting another turbo engine next week.
Dicanio
Member #: 91
Thanks for the responce guys. The shaft is difficult to move, but is smooth when it does, just feels a little tight. I don't think it's run for a couple of years. Thanks for the offer Iain i will deffo take you up on it one day, have you had any engine work done local or could you recommend someone. Cheers again.
Edited by Dicanio on 8th Feb, 2004.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
pour some oil into the drain tube and try to get it to flow to the bearings.. they might just be dry...
See if that cures it... if not its probably new turbo time :(
alex
AlexF
Im having my engine machining done at MBE in lincoln but building the engine myself. He's very good so ive been told and also very well priced.
A while back i got a quote on a turbo short engine, ?650 including the omega pistons built.
I know one lad who had his engine sorted there and he was very good.
Dicanio
Member #: 91
Sorry to be a pain in the ass, but what did the ?650 include, like you i intend on getting the machining done, but actually build the engine myself.
It basically included a rebuild of the short block, rebrind, rebore, new cam bearings, new timing chain all fully built up with new mains, big ends, pistons fitted....
Basically as anyone would build up a newly machined short engine.
He can do anything you like to what stage you want. Bits at a time, whatever. Hes a nice bloke.
Ill get you his number if you like.
Dicanio
Member #: 91
That would be great iain if you don't mind, i'm off next week so maybe able to nip over and pick his brains. Cheers
