Home > Show Us Yours! > Turbo Mods (or ready for the skip!!!)
mini300bhp
Member #: 653
Cambs
I got bored at work today, so thought Id spend some time on my DIY engine build, so started on an old turbo...
Done this on the lathe......
This with a die grinder....(and exhast intake)
And this on the mill.....
Dave, you said about using 47mm cutter, couldn't find one so used a 48mm one.....it went through, so had to weld it up!!! Oh well.
Will any of these mods work??
mod edit: moved to correct section
Edited by AlexB on 12th Nov, 2005.
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
SumpNut
Member #: 28
How do you mean will they work??
Will your turbo still suck air in? - I'm pretty sure it will.
Will the exhaust gas still flow through the elbow? - Probably....
mini300bhp
Member #: 653
Cambs
No....I ment does anyone think they are improvments? Just experimenting, thats all.
what's different to the turbo?
T3Tone
Member #: 252
Sunny suffolk
the inlets been enlarged on a lathe
-MINI CLUBMAN 1380 TURBO-
o i c.
