| Home > Introduce Yourself > 1380 TURBO | |||||||
119 Posts Member #: 772 Advanced Member new york |
20th Nov, 2005 at 04:13:59pm
HI EVERYONE, NEW HERE NEED ADVICE HAVE A 1380 WITH ALL THE GOODIES FORTECH BUILT A+ 73.5 POWERMAX PISTONS, NITRIDED, CROSS DRILLED CRANK, LONGMAN GT6 ALLOY STG3 HEAD WITH S/C GEARS FINAL 3.1 SPOKE TO RICH @ MIRAGE SAID T2 TURBO WOULD BE OK WHAT ABOUT A GT15 TURBO BETTER?? & WHAT INTERCOOLER DO YOU GUYS THINK IS SUUFICIENT? |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
20th Nov, 2005 at 04:22:32pm
Just out of interest, y are you looking to use a gt15? It is a very small turbo, which i believe they use on the Smart Cars little 836cc? engine? A 1380 sure pumps more gas through than that so a T2 will be fine. I know Rich does some good Hybrid t2s, of which i think Nic is running a lower spec one. As for intercoolers, take ur pick, Land Rover TD5, RS turbo, Lancia Delta; wotever u can get to fit!!! |
20th Nov, 2005 at 10:26:08pm
Welcome ! |
20th Nov, 2005 at 11:43:43pm
caps lock button has been removed from keypad! |
21st Nov, 2005 at 06:46:42pm
welcome to the forum -MINI CLUBMAN 1380 TURBO- |
2nd Dec, 2005 at 10:29:57pm
welcome
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
7th Dec, 2005 at 08:26:59am
welcome mate....beware of your compression ratio if it is a N/A head they tend to be higher compression, more so with it being 1380 and a longman head :) you may need to machine your pistons...as i wouldnt want to machine anything off a longman head. of course all depending on if the block has been decked / head skimmed.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
