Home > General Chat > Engine Stand
snowfruit
Member #: 557
Ireland
I'm looking at buying a stand for when I remove my engine. I though I might as well as they're not very expensive and it saves me putting it on the floor or whatever and I can move it around.
Any advise on what to look for on a stand, what sort of weight capacity for example?
clubby_turbo
Member #: 403
sydney Australia
i just went to the local supercheap auto shop n baught a stand, think it cost about $75 and did an awsome job, once u mount'd the engine you could rotate it 360' in one direction, adjustable height so you could raise or lower the height of the engine, it was also on wheels so u could push it around
998 turbo
i have not sen a stand yet that would take an a series without making a bracket up
Dr. jinG
Member #: 368
Roseville, CA (USA)
I just bought one at a local discount tool store (Harbor Freight Tools). I bought the 750lb. model, since you're not hanging even half that weight off the thing.
And yes, if you want all four arms attached, you'll need to make an adapter. But I did mine with three arms attached, no problemo.
1967 Cooper 's' Turbo build @ www.drjing.com
snowfruit
Member #: 557
Ireland
Any reasons not to use it with just three arms? and if there are what sort of bracket needs to be made up?
clubby_turbo
Member #: 403
sydney Australia
mine was just a piece of flat mounted to the stand with some stand off's. 20min job, thought we were talkin about the actual stand though
998 turbo
