| Home > Help Needed / General Tech Chat > levels of boost | |||||||
66 Posts Member #: 775 Advanced Member stourport-on-severn, worcestershire |
25th Nov, 2005 at 09:53:54pm
What is a maximum safe level of boost on a standard turbo cylinder head? If in Doubt, go flat out !!! |
25th Nov, 2005 at 10:58:35pm
if you use a good standard turbo head along with 25cc pistons, it'll probably happily run 30+ psi.
25th Nov, 2005 at 11:04:22pm
sorry for being so basic in my question, im using standard pistons and a standard head with a t2 turbo.i just didnt want to turn up the boost and do damage
25th Nov, 2005 at 11:23:14pm
well, the metro was 7psi using 98ron fuel.
25th Nov, 2005 at 11:41:27pm
Yes hoggy is the best to ask on this one as he is running a standard head on his 1380 so it's even higher c/r. Best 1/4 mile 13.2 seconds @116 mph
26th Nov, 2005 at 11:19:50am
if you are running std pistons with std head i suggest you remove the beak out of the combustion chamber
28th Nov, 2005 at 09:08:25am
yes i ran 10 psi on 9.8 cr with a intercooler with a fixed advance set at 24 deg.
