Home > Help Needed / General Tech Chat > suspension
nogin
Member #: 487
westbury, wiltshire
need to get this sorted as having some trouble, getting a lot of sidwards pull on both acceleration and deceleration, which i think could be down to unequal caster settings, do normal four wheel alignment places deal with this or is it a bit more specialised, i live in south west if any one knows of any were that could help cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
i set my caster to 5.5 deg this helped some what but.....
what cured my torque steer altogether was the fitting of the minispares xpin diff
have you got the tea trolley affect????
remember if you increase your CAMBER you decrease your caster !
make sure all the suspension bushes are all in order firstly and the subby mounts to the shell!
andeh
Member #: 97
Near Daventry, midlands
im unaware of places in your area unfortunatly, but i'd suggest trying to find a local racer and ask them who they use. General places wont know how to measure or adjust castor which will definatly (providing sus/sub bushes are all good) be the problem if its happneing under breaking. Small posability that the ends arnt matched i.e the car is crabbing as this can also cause similar problems
Edited by andeh on 26th Nov, 2005.
Dangerous
Member #: 417
Imperial tyres in swindon are pretty good
nogin
Member #: 487
westbury, wiltshire
do they deal with lowered cars as mine is and the local places wont touch it lowest point is 7cm but they do my other mini which is lower cant work it out
i also make things
like i said,the caster has decreased some what!
been this low
thats if all other bushes etc......mentioned are all inorder
Dangerous
Member #: 417
Yep they should do,In the reception area there are loads of pictures of race cars and kit cars they have set up
You get a big printout of what the settings were before they started and what they have adjusted them too
nogin
Member #: 487
westbury, wiltshire
cheers mate
i also make things
Dangerous
Member #: 417
http://www.imperialtyres.co.uk/
