Home > Help Needed / General Tech Chat > Length of the CSK screw in the rad side engine mount
Can someone tell me the length of the above please? I havent got a screw and i'm just going to counterbore the ally block and pop a normal bolt in but i dont know the length.
If you could give me the overall total length then i can work out what i need.
I cant get the one out on my spare engine *frown*
Not having much luck at all with getting this engine in!!
Thanks *smiley*
I can't get mine out either. I did try though.
Wil
Cheers mate *smiley*
Its a right little fooker hence getting rid of the phillips head and going for either cap head or a normal bolt. Something you can get a decent hold of!
Give it some cosh with an impact driver, that usually shifts them.
I could go outside and measure it for you, but its too fucking cold I am afraid. Also would be a best guess, as mine is screwed into the box and the engines in the car.
Yeah, but unfortunately its had some abuse before and now its fucked *frown* told you i wasnt having much luck this last week!!
No worries mate, ill have a play with a bit of wire, just thought someone might have one to hand *smiley*
its 3" long, welded a nut to the little fucker and wound it out.
