| Home > Help Needed / General Tech Chat > Fuel pump pressure | |||||||
23 Posts Member #: 461 Member Queensland Australia |
30th Nov, 2005 at 08:21:19am
Hi all, |
30th Nov, 2005 at 08:33:07am
The Metro ones gives about 36 psi, i tried a pump from a a big BMW and it damaged my regulator. Though i never measured the exact pressure it gave, i'm guessing it was somewhat higher than the Metro item.
30th Nov, 2005 at 09:16:35am
a 55psi pump should be fine. I'm using a 65psi pump no problems.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
4th Dec, 2005 at 10:17:25am
Any style injection pump should fit the bill.
8th Dec, 2005 at 09:37:23am
Fitted the pump off the nissan, no problems so far. But it sure seems to have fixed some niggling performance problems. Time will tell.
9 Posts Member #: 555 Junior Member |
26th Jul, 2006 at 06:14:04pm
Do you know whether this Fuel Pump would be suitable? The pressure looks ok but I'm not sure about the flow rate? |
