| Home > Help Needed / General Tech Chat > oil cooler | |||||||
102 Posts Member #: 155 Advanced Member |
12th Feb, 2004 at 09:31:49am
do you have connect the oil cooler ? |
12th Feb, 2004 at 11:01:06am
Yes, you need an oil cooler! The best types are thou with a thermostat so they don't over cool the oil in cold weather.
AlexF |
12th Feb, 2004 at 10:48:17pm
AlexF2003 , sorry but i don't agree with that!
13th Feb, 2004 at 12:00:16am
I knew you'd spot this post MW!
Edited by AlexF2003 on 13th Feb, 2004. AlexF |
13th Feb, 2004 at 06:26:40pm
LOL your right Alex! well one thought one would have a little say Best 1/4 mile 13.2 seconds @116 mph
13th Feb, 2004 at 06:40:30pm
my turbo runned very fine , without an oil cooler for one year.
13th Feb, 2004 at 09:12:16pm
Where do you measure your oil temp MW?
AlexF |
14th Feb, 2004 at 12:26:30am
What?
14th Feb, 2004 at 10:18:26am
Id agree with that dave, i took reading off the pressure feed and with the cold air coming through the grill it distorted the reading. Covered up the grill and the temp went up by 20 degrees! (reading not actual oil temp!)
14th Feb, 2004 at 11:47:53am
In the engine post pump :p
AlexF |
14th Feb, 2004 at 04:38:53pm
Everywhere says to mesure it in the sump, via a modded sump nut or probe on the dip stick or something...
14th Feb, 2004 at 06:31:08pm
You have a gear set in there... its finned alloy in design... so nearer the edges will be cooler than the centre..
AlexF |
14th Feb, 2004 at 06:44:57pm
Alex
14th Feb, 2004 at 08:03:18pm
Alex, I take the reading as it come out of the block and goes to the filter.
14th Feb, 2004 at 11:18:48pm
agreed!!! Was just interested :)
AlexF |
15th Feb, 2004 at 12:05:24am
MW mite be worth trying covering up your grill.. as iain says the temp readings were distorted here..
16th Feb, 2004 at 06:24:05am
I measure the oil temp at the big banjo bolt head in front of the engine. I have a front mounted radiator so if your cooling theory is solid my setup may infact show temps too high. Since the hot air passes through the radiator it ends up against the block.
17th Feb, 2004 at 06:25:27pm
Hi evolotion, My grill is quite covered up mate, just a thought if oil temps get distorted here that much maybe people should fit a short rubber hose with a oil temp take off, instead of an oil cooler if it cools it down that much.
