Home > 998cc > engine venting
akirch
Member #: 399
Austria
Hello,
Now I installed a standard-998 engine with T3-turbocharger, because my 1293 is out of action at this time. It is just for experimentation, how long this will keep alive... *evil*
Do not worry about the engine.
One question:
On the backside of the 998-block i mounted a second cover without venting, because there is no place for it.
Is it enough, to open the clutch case for venting (which is closed at the 998-engine)?
It is not for a long time... *wink*
Andreas
http://www.minifreunde.at
benjamin
Member #: 621
nsw austalia
just put a rocker cover on it with a breather saves you drilling holes and such and would be enough breathing for a 998 i think
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
All I've been using is the vent on the flywheel cover and it's been ok.
I'm adding a vent to the rocker cover over the winter though.
Wil
