Home > Help Needed / General Tech Chat > flip front Q's
t3gav
Member #: 229
Gavin@minispares.com
kent
been looking at different options for my car recently and cant make up my mind whether to go the flip front route, have read other posts and their are very mixed opinions, one of the main things i wanna know is who uses a flip front with inner wings or do these not exist, surely you get loads of crap thrown into your engine bay without them? oh also whats the best way to disconnect lights etc any pics greatly appreciated,cheers
nigel
Member #: 733
Gatwick
you hit the nail on the head gav, crap gets thrown up all over the place, I only have to go down the road in the wet and everythings covered in mud etc.
On the other hand when you have a flip front you have so much more access and with the front removed its a doddle to do anything.
Go for it but buy a pressure washer..
Oh and don't forget to tighten everything down before you set off on a blast, I didn't and the car stopped but the front didn't?
mine never got too mucky i found, occasionally i used a gentle hosing over with the engine running
when i first got the car it had some inner wings replicating the std ones, you could always knock some of these up
mini300bhp
Member #: 653
Cambs
Mine dont get to dirty, but I don't use it in the wet.
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
turbo hogster
Member #: 178
stowmaket suffolk
mines ok, doesnt realy get dirty, loose the inner wings this gives much needed room to use.
my lights ect are on bick quick release connectors from demon tweeks
Nick
Member #: 154
Midlands
all my lights are connected up via a trailer plug for when you take the front end off totally. If you go the flip route i seriously recommend a 2 piece, its a right pain in the cock having to flip the whole thing to check oil/water etc.
i'm gonna replace mine with a steel removeable front, just have it bolted on but can be removed for major engine surgery, then just use a FG bonnet with pins for day to day stuff.
here's a pic of mine, you can see the trailer plug on the left of the bulkhead, and how much road spunk has been thrown up the inner wings/engine in the last 2 weeks while ive been using to go to work and back.
Carl
Member #: 95
liverpool-on-sea
ive not got a flip front but i always thought of the idea of using trailer mudgards under wings to stop muck being thrown everywhere.
A mate of mine had a flip front, we fitted plastic shields roughly where the inner wings would have been, improved matters no end.
t3gav
Member #: 229
kent
thanks *happy*
Well my engine is white with salt atm, and I have a standard front end.
If you're going to do it deffo by a two piece one as Bud said. As well as being better for general everyday use, it also means you don't have to cut the front arches; they never look good when cut.
Wil
t3gav
Member #: 229
kent
how come wil do they come pre cut or not cut at all?
