| Home > Help Needed / General Tech Chat > k series turbo | |||||||
32 Posts Member #: 81 Member |
15th Feb, 2004 at 04:33:04pm
hi all, i havent been here in a while, Dave Fletcher A.M.I.M.I |
15th Feb, 2004 at 05:26:18pm
![]() 323 Posts Member #: 41 Senior Member |
15th Feb, 2004 at 06:49:37pm
nothing to do with the question your asking, sorry, but just curious how much you paid for it?
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
15th Feb, 2004 at 11:00:10pm
some may consider this a bodge, but if the k series uses multi layer metal gaskets like the pug/citroen TU series engines then you can double up gaskets to lower compression. Theres alot of supercharged and turbo'd 106's and saxos going about whith this and no head gasket failures that i know of. turbo 16v k-series 11.9@118.9 :)
3 Posts Member #: 153 Junior Member |
17th Feb, 2004 at 11:33:40am
I saw this on another forum might be worth considering, check out the bit about the rs turbo on a k series!
18th Feb, 2004 at 10:18:55pm
i dont fink youll be able to put two head gaskets on as they are made of aly and have rubber bonded on to seal the various parts and they are very prone to head gaskets blowing so research turboing one as much as possible. no longer a series, but still 1.3 turbo.
21st Feb, 2004 at 07:03:25pm
cool thanks a lot guys, will need to do a bit more research me thinks
