| Home > Help Needed / General Tech Chat > Engine problems! | |||||||
46 Posts Member #: 171 Member Portsmouth, Hampshire |
15th Feb, 2004 at 06:05:04pm
I have recently had problems where my car will lose all power and stop i.e. foot to floor and car slows down and dies. |
15th Feb, 2004 at 07:51:38pm
Mine did exactly the problem you describe! (god i had a lot of teething troubles to start, good way to learn though!)
16th Feb, 2004 at 12:57:22pm
I have just recently added another Bad boy earthing strap as i was experiencing trouble with the charging system and altenator. I need to do a run about in it to see what the fuel is like in the return! thanks for your help will keep you posted! |
16th Feb, 2004 at 07:57:02pm
I have concerns maybe that it is the fact that i have a standard fuel tank with standard outlet pipe and home made return. It has also come to my attention that there maybe fuel vapourisation in the float chamber. Other than that im stumped I have ordered a new fuel pressure reg. and hoping that I have not wasted my money just eliminating an item under the bonnet. The car would not start today as i have been away for a couple of weeks so hope fully I can try things tomorrow! |
16th Feb, 2004 at 09:38:30pm
Try an inline filter before the carb and see what happens. There really should be no problems starting at all.
244 Posts Member #: 34 Senior Member |
17th Feb, 2004 at 10:54:00pm
You haven't changed the plenum to carb gasket recently have you?
