Home > Help Needed / General Tech Chat > clutch
jufferb
Member #: 775
stourport-on-severn, worcestershire
What would be a good clutch upgrad over standard? What is a orange and grey cluch? is it worth lightening the flywheel whilst it is off?
cheers
If in Doubt, go flat out !!!
T3Tone
Member #: 252
Sunny suffolk
What sort or power are you after??
The orange and grey are the types of diaphram, i think because of the torque of a turno lump a grey is a good option along with an ap fast road/ rally plate. Lightening the flywheel will help acceleration, not sure how far you can go safely with the cast iron flywheel though?
-MINI CLUBMAN 1380 TURBO-
jufferb
Member #: 775
I want about 130-140 bhp. I was thinking of replacing the fly wheel with a 998cc fly whell and then have it lightened further. I think by changing from a 1275 to a 998 will save 8lb's
I assume you're talking about the ancient Austin 1300 flywheel???
All later stuff is the same
jufferb
Member #: 775
The flywheel weight saving i was told by an old bloke so your proberly right. is the clutch a verto or non verto?
http://www.manchesterminis.co.uk/technical...bleshooter1.htm
YOU tell us what kind of clutch it is, and WE'll advise!
turbo hogster
Member #: 178
stowmaket suffolk
i run a grey diaphram with a ap rally plate with no probs to date using a ultra light flywheel.
Carl
Member #: 95
liverpool-on-sea
are the plates the same in a verto and non verto clutch?
The metro turbo uses a 'non sprung' centre, as does all pre-verto stuff. Yes - they are the same.
jufferb
Member #: 775
i think its a verto because it has the short stumpy clutch leaver on the bell housing. could you correct me on this if im wrong and will the grey diaphram and ap racing clutch fit.
RED850
Member #: 89
Sydney Australia
yes its verto then, i run a ap race rally too with a grey cover diaphram and once i set the back plate to the flywheel its been sweet.
if you lighten it heaps you will loos e a little bit of torque but gain engien rpm acceleration, i have gone back to a std non verto flywheel this engine build cause i want as much torque as i can get.
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
