Home > Help Needed / General Tech Chat > Petro Sink
Zeemax Power
Member #: 393
Oulton Park
i can't work out why i get it there no leaks in the tank and i'm using the same fuel lines that came off my spi mini but the stink of fuel is strong i have ran a pipe off the brever twice the size and ran that out to the under of the car but i have a diferent fuel cap that doesn't let air out but i have even sealed that up and still smell fuel work it out i can not any ideas worse first thing in the morning when the car hasn't been used
http://www.Zeemax.com
SumpNut
Member #: 28
check fixed metal lines for small splits which only leak when under pressure. Its common on N/A minis with improperly fitted LCB's whcih crush the old fuel line.
But anyone that leaves a fuel line next to an exhaust deserves to be burnt for their stupidity!
Zeemax Power
Member #: 393
Oulton Park
tents to be worse when left over night
turbo hogster
Member #: 178
stowmaket suffolk
sheck tenk breather hasnt came off
Zeemax Power
Member #: 393
Oulton Park
not that but inlets leaking a bit could that be it
i would say its a good place to start!
