Home > General Chat > Just started the yearly rebuild.
I'll keep you up dated on the progress.
Here we go again......... Still have only around a 1 metre square floor space to work in as my shed still in a right state.
I keep knocking over me pots of nuts and bolts, it's really getting to me...........I need more room!
andeh
Member #: 97
Near Daventry, midlands
hope u got a good heater :)
Carl
Member #: 95
liverpool-on-sea
good luck mat dont forget to show any worn bits.*smiley*
matt, i have PM probs.
mail me
carl
ok fastcarl, yes ill keep you up dated, no heater but that would be an idea*wink*
turbo hogster
Member #: 178
stowmaket suffolk
that would a fing disaster you thought hemel hempsted is a big blaze.
they would have to evacuate the whole of suffolk if he puts a heater in there. lol.
yes its a little toxic in there, but ive seen your shed to, and you cant talk, but haveing said that you can get in yours:)
evolotion
Member #: 83
Glasgow, Scotland
matt, i use an oil filled(mains electric) heater in my "hut" .. cause theres no exposed eliments theres no fire risk, and no danger if it gets knocked over / you pour something over it. cheap too, think mines was ~£20.
never liked useing exposed eliment heaters in a petrol/thinners soacked environment.
Edited by evolotion on 13th Dec, 2005.
Denis O'Brien.
Hay, Evolotion that sounds like a great safe idea*wink* cheers.
Just checked me cam timing and it was 7 degress from what it should have been for some reason!!!! i've checked it lots of times so i was doing it right.
weird this one.
T3Tone
Member #: 252
Sunny suffolk
Remember you still got 218 bananas with this cam timing and similar power when it was spot on and felt the same at the bottom end!
Edited by T3Tone on 14th Dec, 2005.
-MINI CLUBMAN 1380 TURBO-
funnily enough Matt , i found my cam timing to be 2 degs retarded from what i set it two years ago ,so i suspect stretched chain . but 7 you must have done something wrong somewhere,surely. are yopu turning it the right way lol.
carl
turbo hogster
Member #: 178
stowmaket suffolk
rev oil heaters.
belive me these do catch fire , they used these alot out in bosnia to heat up the pongos rooms in the winter we had loads which catch fire as the element gets knocked it weakens the join to the heater and oil starts to leak into the element chamber and bingo she goes up so be carefull when using them.
Well that's from a fireman, so yes be careful.
Yes Carl what i can't work out, is i do the same thing evey year and, i found it this year, i haven't changed the way i did it, but i guess it was a half a sleep moment.
evolotion
Member #: 83
Glasgow, Scotland
On 15/12/2005 04:59:56 turbo hogster said:
rev oil heaters.
cheers, got mine mounted where it doesnt really ge tbumped, and stil alot more comfortable with it than with a fan heater(for example).
good info though, mite move it away from the 4ft propane tank
*tongue*
Denis O'Brien.
turbo hogster
Member #: 178
stowmaket suffolk
also polystyrene isnt a good idea nether if that catches fire it will burn like a barsted,
best thing is to line the shed with stirling board.
Cheers mini1071s, didn't realise those boards were so cheap*wink* i no it's good stuff from when i was on site.
KINGSPAN.
mini300bhp
Member #: 653
Cambs
How many miles do you do between rebuilds?
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
turbo hogster
Member #: 178
stowmaket suffolk
1071 yes i know the stuff its very good.
