Home > For Sale > Turbo bits and pieces...
dan
Member #: 93
Few bits up for sale to try and raise some desperately needed cash!!
can post any of this stuff to within the UK, please pm if interested, and can send pictures of all the stuff, and yes I take paypal :)
- Turbo Inlet Manifold - £30 - SOLD
vapor blasted, thick aluminium spacer plate bolted to carb side and blended into manifold, pressure take offs tapped 1/8 NPT ready, brake servo take blanked off using screw plug, back side of the flange on the head side has been stepped down to suit mirage manifolds
- Mirage Motorsport Turbo Manifolds - £300 - SOLD
as purchased only used for fitting up, never actually been run, slight tidying up done internally to help flow
- Montego Plenum - £75
vapor blasted, group A dump valve welded on, good bit of tidying up done where take off pipe bolts to help with flow, new 12 point bolts, std dump valve position welded up, alloy boss welded and tapped ready for air temp sensor to be fitted M12x1.5, other pressure tappings 1/8 NPT, clamping to carb has been revised using 2 M10 allen bolts accessible from the front as opposed to the std long bolts which have to be got at from the back of the plenum although can still use std bolts, sprayed using high temp black paint
- Brand new 3" S/S Elbow with v-band adaptor - £50
Quality S/S Elbow from ATP Turbo in the states
- T2/T25 S/S V-Band adaptor - £50
Quality S/S V-Band adaptor from ATP Turbo in the states, bolts to where the std elbow fits and allows use of v-band connections to exhaust pipework
- T3 Internal Billet Wastegate Actuator - £30 - SOLD
Collins T3 actuator fitted with a 16psi spring
- Garrett T25 Turbo - £100
T25 removed from low mileage Rover Tomcat, comes with a brand new compressor housing (£120) that doesn't have the pesky integral dump valve which gets in the way with your mirage manifolds!! Exhaust housing been drilled out to take studs from turbo manifold. Will come with std actuator, and std braided oil feed hose etc. Radial float been measured at 0.002" which in comparison for T3 spec of 0.003-0.006" backs up it being low mileage.
- Metro Turbo Fuel Pressure Regulator - £15 - SOLD
As per the title, removed from a running metro about 3 years ago, been stored since
- Manual Boost Controller (MBC) like a bleed valve - £10
Not been used, bought off ebay ages ago
Edited by dan on 28th Dec, 2005.
Dangerous
Member #: 417
If it's a straight replacement for a normal metro actuator,I'll have it
How much incl postage
dan
Member #: 93
brian, just been out to the garage and compared the billet one against the std one
looks like you would need to use screw-on part which clips over wastegate lever off the std one on the billet one and it should be ok, the 2 mounting bolts for the actuator look to be the same
total price inc postage to you sir £35
I've used one of these and other than having plenty of space for the air pipe all you need to do is swap over the adjustable arm as dan says.
*smiley*
TURBO ME
Member #: 772
new york
pm me with pics of intake manifold , plenum & mirage manifold thanks
garethlloyd
Member #: 616
Birmingham
mail sent!
pm sent Dan!
dan
Member #: 93
remaining bits and pieces now on ebay
for the vband thingies, I presume id need a compatible downpipe...can you get the v band flanges to wend onto a downpipe or would one need fabricating?
Edited by joeybaby83 on 12th Jan, 2006.
nevermind, just found some on the net.
clickity click http://search.ebay.co.uk/_W0QQsassZmini934QQhtZ-1
MaltaMini
Member #: 510
Malta
You said there is a crack in the turbo - does this mean it needs a new housing?
Mark
I donated, but somehow didn't get the label! :(
dan
Member #: 93
turbo and v-band stuff is now sold
but for info the crack is very small, its not unusual for T2's and T25's to get cracking in this area in about 5k miles! So long as the cracks are not big enough to lose an appreciable amount of air through its not a problem
dan you wolly, was gonna bid on them!
