Home > Ebay items For Sale > turbo crank 6581.....how much???
Nick
Member #: 154
Midlands
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...me=STRK:MEWA:IT
£150!!!???
Now this is interesting!
I've never seen a crank that has been 'stamped' as CAM6581 - it's usually forged (raised) digits...
But - it looks to have the large radius between the primary gear bush larger diameter and the primary gear inner thrust face...
It'd be interesting to find out if this was an 'early' 6581 or a very late one...
i have a 6581 crank and it is not stamped its raised
makes you wonder if its not a con???
giallofly
Member #: 164
The Stig..
Newport Pagnell
then there is this little lot..
Note the inlet manifold?
http://cgi.ebay.co.uk/mg-metro-turbo-carb-...1QQcmdZViewItem
Nick
Member #: 154
Midlands
holy shit it went for over £170!!! fook that!
that doesn't even look like turbo carb to me jon let alone the fannymould.
Doodmeister
Member #: 149
Alberta, Canada
Are they a rare item then these CAM6581 cranks ?
it would appear so - only found in metro turbo's - and only ones made after mid '86 at that...
Doodmeister
Member #: 149
Alberta, Canada
I should take better care of the couple i have lying around the garage then.
Dangerous
Member #: 417
The only thing I have noticed is my 6581 has been sat in the shed for a few months and shows no signs of rust,where as normal metal goes rusty in no time
Doodmeister
Member #: 149
Alberta, Canada
SO what is the BIG difference then.. (Forged)? or just a better cast with bigger fillet radiuses.
Well, From my experience - you don't put a different number into a forging for the same basic machining and a different HT...
This suggests a different material to the 6232 crank.
Tom Fenton is on the case... *wink*
Nick
Member #: 154
Midlands
or at least he will be when i remind kean to post his knackered 6581 off *blush*
*happy* *happy* *happy*
haveyoubooked
Member #: 4347
Highlands
i think they nitrided as standard or somethin that makes em harder. I got one in my engine. got block, cam, crank, pistons and turbo off ebay for 100 quid in june. quite pleased wi it all, new set o' bearins, quick hone of the bores, skim o' the block, oil pump and bobs ur uncle, fanny's ur aunt!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Badboyboost is that you?!
AlexF
I've skimmoed my block as well. Makes it flat n'all. For sure.
Fenton. Did you ever check out those cranks??
Richie
Member #: 628
i have heard the 581 was toughened it is mentioned in the vizzards hook if i recall. most metros have the 232.
Mine is fitted with a 581 and again the numbers are embosed not engraved. so it seems a bit sus
and alex if it is BBboost i will be happy i didnt let him come to my house and try to start the car *wink*
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
OK, to the top again. Is there anyone here who infact, can check this? I'd chip in for the expenses on such a test. Anyone else?
Tom?
I'm a pedantic viking cunt, just to let you all know!
Edited by Tom Fenton on 17th Feb, 2010.
welshdan
Member #: 1111
s wales
LOL
Hahaha!
To be honest, I'm more curious...
On 17th Feb, 2010 Vegard said:
To be honest, I'm bi curious...
I thought you had been calling a few too many things gay recently...
Edited by apbellamy on 17th Feb, 2010.
