| Home > Help Needed / General Tech Chat > roll cage tubing | |||||||
969 Posts Member #: 47 Post Whore Not very sunny swanage |
17th Dec, 2005 at 12:51:15pm
anybody know where to get this from? i want to add a harness bar to my existing cage... its 1.5" dia if that makes any differnce... obviously needs to be the correct stuff....
And on the 7th day........... God created turbochargers! |
17th Dec, 2005 at 01:06:52pm
merlin sell it by the meter asmore and allen sell it to order Crystal Sound Audio said:
17th Dec, 2005 at 01:08:00pm
Blue book says:
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
17th Dec, 2005 at 03:11:27pm
will you not invalidate your cage (if its an fia one) by welding to it ?
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
17th Dec, 2005 at 03:52:11pm
probably, but its not a new one anyway. dont have any documents for it, so not too bothered. sticking to all of the regs as a minimum saftey standard rather than because i ever plan to race it...... And on the 7th day........... God created turbochargers! |
17th Dec, 2005 at 04:28:00pm
FIA now is 3mm wall thickness seamles tubing
17th Dec, 2005 at 08:50:28pm
You shouldn't affect the approval of the cage if you are only adding parts.
18th Dec, 2005 at 11:22:43am
my thought was by adding heat to the metal you are changing its tensile strength etc etc
18th Dec, 2005 at 01:00:51pm
Yes M.F.T. you,re right the welding could affect the tubing, but it,s so thick it won,t be a problem.
19th Dec, 2005 at 12:13:01am
okee doak mate :)
19th Dec, 2005 at 07:39:34am
What about fitting the new Safety Devices BOLT IN belt bar? It's mandatory in Mighty Minis, and I've got one as well. It's FIA colpliant as well.
