Home > Help Needed / General Tech Chat > whats this all about
nogin
Member #: 487
westbury, wiltshire
the last bit im on about the copper sulfate grease, is this copper slip
Before fitting the new MINISPARES flywheel, careful examination of the crankshaft taper for burrs
and pitting is required as this could cause incorrect seating of the flywheel, which would
lead to the two parts friction welding together at high RPM and irreversible damage to the
crankshaft and flywheel.
A fine valve lapping paste should be used to ensure the two tapers fit together as near perfect
as possible, this can be confirmed by an even grey finish over the whole taper. The paste should
then be washed off thoroughly and copper sulphate grease applied before the final assembly.
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
I have never heard of using any sort of grease on the flywheel taper?
Certainly lapping the tapers in is standard practise, but I have always fitted the flywheel ensuring the tapers were both spotlessly clean.
as tom says
do i need to re-lap after taking off the flywheel and later refitting it to the same crank?
or will just cleaning the tapers be suffice?
relap it back on to do it right
it goes a long way to help prevent fretting
turboestate
Member #: 362
durham area
copper sulfate is indeed (copper slip) dont want it on there though just asking for touble :cool:
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
why would you want to promte movement?!?!
Fretting is the result of movement and destroys cranks!
Alex
AlexF
someone should try it....shotgun not me.
Richie
Member #: 628
good idea you could set up a target in front of the car then rev the car and see how far through the target the flywheel goes...along with what ever it takes out of the engine bay with it lmao :):):):):) could be a new olympic sport............Tom has deffo ansered this one for you... i also follow his rule.
Rich
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
